15" wheels will not fit, at least without some modification there has been a couple people if im not mistaken alter the caliper etc to fit 15's though.
with respect to the 10" wide you should be fine though, especially if your looking to go with a smaller wheel (but it might poke) as many have 9.5" with their 18's and 19's
Couldn't you find another Toyota with the same bolt pattern and swap the entire brake, caliper setup? You'd probably lose braking ability unless you got good components but you could run 15s and as long as it all lines up shouldn't be too hard of a swap.
And I don't think cooling would be an issue if you get open wheels, obviously steelies aren't going to vent like 5-spoke konigs.
