1 - 2 of 2 Posts
Discussion Starter #1
$1350 OBO
I have a set of 4 Mtechnica Turbo 18x9.5 +36 5x114.3 73.1 center bore wrapped in a set of 225/40r18 Good Year Eagle F1 Asymmetrics. Tires are between 5-6/32nds tread. The second iteration of our 935K inspired turbo wheel. Keeping with the concave styling of the turbo fan we raise the outer ridge to keep the concavity with the higher offset requirements that modern sport compact cars require. The barrels are rotary forged to keep weight savings down to 20lbs. One important factor most manufacturers do not emphasize is that weight savings is only as valuable as the max.load of each wheel. The Turbo 18inch max load is tested up to 735kg per wheel. Well above the standard VIA/JWL standard required. No bends are cracks, faces are powder coated gold with black recessed areas. Tires are evenly worn. No feather or chopping. Will not ship. Willing to meet within 400 miles.
Sent from my iPhone using Tapatalk
1 - 2 of 2 Posts
