Installed and used for maybe a month. Looks new. Purchased a new Scion badge from the dealer and plasti dipped it black and stuck it on. You can remove the black and keep the badge silver or simply remove the badge for a clean look.
I'm also including the upper trim part that is from a cut stock grille. If you buy this grille new, you are required to cut your factory grille, making it useless and impossible to go back to stock. I'm including this part so you can simply remove your grille and you won't have to modify anything.
Installs in minutes using mostly stock bolts.
Paypal $100.00 shipped fedex anywhere in the US with tracking numbers supplied.
