2008 Scion xB Light Bulb Sizes
72836 Views 15 Replies 12 Participants Last post by  juddsandage
Below are the types and wattage of bulbs on the 2008 Scion xB. Please use care in replacing and do not use too high a wattage... Mishandling of bulbs can result in bursting, shattering, or shorter lifespan.
Headlights (low) - #9704 - 55W - H11 halogen bulbs
Headlights (high) - #9005 - 60W - HB3 halogen bulbs
Foglights - #9704 - 55W - H11 halogen bulbs
Front turn signal lights / parking lights - #1157NA - 27/8W - Single end bulbs (amber)
Front side marker lights - - 5W - Wedge base bulbs
Side turn signal lights - - 0.4W - LED
Rear turn signal lights - 7440 - 21W - Wedge base bulbs
Stop/tail lights and rear side marker lights - 7443 - 21/5W - Wedge base bulbs
Back-up lights - 7440 - 21W - Wedge base bulbs
High mounted stoplight - - 3.6W - LED
License plate lights - 194 - 5W - Wedge base bulbs
Interior light - 28mm - 8W - Double end (Festoon) bulbs (30mm can fit)
Personal light - 194 - 8W - Wedge base bulbs
Luggage compartment light - 28mm - 5W - Double end (Festoon) bulbs (30mm can fit)
1 - 16 of 16 Posts
License plate lights and map lights are both 194's (just upgraded em to LED)
very good to know. i search for a while at SL before knowing which bulbs to buy for the license plate, front turn, and reverse lights
I just added that info & the foglight bulb size (H11) to the OP
Can we please pin this (make a sticky topic) please? I found this to be super useful! This is what I had to go through to find it again:
I had to search forever to find this again
:book:
I started getting tired (12:22am)
:yawn:
Then I found it!
8)
Only to find it here in Audio / Electronics, but way at the end
:eek:
I did try the search option but the only key word I could think of was light and chart (which wasn't even a part of this) :eek:hno:
So, yeah, if we can stick this up it would be awesome!
Thanks! :D
Sure... *pinned*
You can also find this and more posts like it by clicking the "Scion xB Info" link at the top of the page.
http://newscionxb.com/information.php
I search for a while at SL before knowing which bulbs to buy for the license plate, front turn, and reverse lights
sylvania.com also!
What are the bulbs for the temp, fan level (A/C) dials? I know the centers of the dials are PLCC 2.
They are Neo Wedge Type B, and the center button lights are 3mm LEDs not PLCC-2
Thanks xtylerx. I meant to type 3mm. I must have just looked at something else before typing. I finally found the neo wedge type B. They are on the way.
Could you use a 1157 for the turn signals instead of the 1157na?
where
can u get these? been looking for this thread too
im looking for the type of bulb it is to change the shifter plate light for the automatic i want it to light up blue! any help would be appreciated
I too am looking for the bulb type for the shifter plate, I got the wrong neo bulbs for the A/C Controls, 5mm instead of I think the 3mm it needs... well at least the 3mm off of superbrightleds.com
1 - 16 of 16 Posts
