1 - 20 of 28 Posts
Discussion Starter #1
I moved this conversation from here since things were going way off topic-
http://www.newscionxb.com/153-member-pics/11842-started-bottom-08-sand-black-pearl-7.html#post181914
Don't install resistors just buy the LED Flasher Relay that will take care of the hyper blinking. It cost $45 but it better than having to splice into wires.
I tucked the HID ballast behind the headlight against the fender (velcro to a flat metal then zip tied it also)
Too late now. I ended up making my own rig of bolts, washers, and a flat piece of metal and mounted the resistors to the underside of the metal arms above the headlights. It looks pretty clean. It was a pain but I'm glad I went to the trouble because those things get hot!!
How do you use the LED flasher relay? You don't have to splice wires? I might go that way for my rear blinkers then. Have any idea what to buy?
Diode Dynamics' site says
Flasher Replacement: You may have heard of replacing a "flasher relay" instead of using resistors. Indeed, some vehicles have a replaceable flasher relay, and it is possible to replace it with one designed for LED use, to eliminate hyperblinking. However, this is only true for some vehicles. We do not believe one is available for your vehicle, because your flasher is built-in to the vehicle's computer. You will need to use resistors for your vehicle.
I bought a relay for my 09. I can't imagine it is any different.
I think mine came from ledmod.com - looking at that page though it says 08-10. Maybe 11+ already have digital relays.
Hmmmmmm
At Diode Dynamics' site, here is the front blinker for 2004-2010
2004-2010 Scion xB Front Turn Signal LEDs (pair) - xB - Scion - Bulbs By Vehicle - Lighting
It gives the option for flasher module or resistor kit.
For 2011-2014, there is only the resistor kit.
2011-2014 Scion xB Front Turn Signal LEDs (pair) - xB - Scion - Bulbs By Vehicle - Lighting
Well, LEDMod has a switchback front blinker for 2011 and up, and it has a flasher relay as an option. Hmmmm..
Scion xB2: Dual Color LED Turn Signal Switchback [2011 and up] [xB2_dual_LED_bulb] - $44.99 : Zen Cart!, The Art of E-commerce
So I sent a message to LEDMod asking about the relay on 2011+, because Diode Dynamics' site contradicts. If I can use the relay instead, I'll get rid of my resistors and use that. Actually, if I change my mind and decide to try the switchbacks, I can move my current front LED blinkers to the rear since I haven't replaced those yet. I wish I knew how bright the LEDMod swithback blinkers were compared to my current LED front blinkers, since I got some that are a little brighter than stock and they look great.
I was wondering what the heck happens with the parking/clearance lights if you get their switchback bulb, since we 2011+s have the separate light. Well in the photobucket photos they have there, it looks like they put a little LED thing into that socket after all, and I can see how they wired it. It sounds like the relay just replaces and existing one under the steering wheel. Interesting.
I'll post back here when I have some answers.
Discussion Starter #3
Those switchbacks look pretty cool. I'm not sure about the delay after you turn the turn signal off though. **** I'm picky!!!! lol
Hehe. Yeah I also wondered about the delay - more about the delay when you turn it on. If you notice, in the video when they turn on the parking lights, it takes a little longer for the switchback to turn on. Also, during the initial blinkering, it stays on yellow for a bit longer than the rest of the blinks. I guess this is the relay working? The delay after turning the blinker off doesn't bother me.
Discussion Starter #5
Ok, I got a reply from Sean at LEDMod-
"We've installed the flasher relay on 2011 and up models without a problem. Not sure why other site would say that.."
So now I'll ask the guys at Diode Dynamics to look into it because this apparently works. I'll stick with them on my future LED purchases if they help me out.
Discussion Starter #6
Ok, Diode Dynamics has replied that:
From what we have seen, the 2011+ XBs cannot have the flasher replaced, or there needs to have modifications made to allow this to happen, as it is more than just a simple plug and play! Each car can be different, so I do not want to dispute what any other company has done, as they certainly may have found a solution with this modification, we just do not feel comfortable making customers do this with the chance of ruining anything.
I can respect that answer, and being cautious with their compatibility info. It looks like LEDMod.com says you need to break little plastic tabs off the flasher relay to plug it in, but that is listed as 2008+, not specific to 2011+.
Well I guess what I'll do is check out what mine looks like, and the numbers on it. I'll look in the manual too. I'm not sure if the relay is for all 4 blinkers or just pairs of 2 so I'll look for that, and maybe check the docs we have online.
I do see that iJDMTOY has what looks like the exact flasher relay that LEDMod includes with their switchbacks for pretty cheap, $12 shipped on Amazon. I may just have to try that.
Discussion Starter #7
Discussion Starter #9
The flasher is for all 4 turn signals. I've got one in my 08 and it's been working great for a couple years now.
Thank you, Greg! I'll order one then.
I tried briefly to pull out the driver's side dash panel to see the fuse box, but didn't get it all the way off yet. I love how the manual just shows an arrow pulling away from the panel. So you just yank it off huh? I'd love to not break any tabs or something. I searched around including here and somehow was unable to find any information on how to remove it or what it looks like and what flasher relays there are. I got under the steering wheel with a flashlight at lunch and pulled free the first few tabs toward the bottom edge. I guess I'll leave it there for now until I get the flasher.
My plan now is to just go with the blinker LED bulbs I have now on the front, and get another pair for the rear from the same place. I'm pretty happy with those - they're a bit brighter than stock and look good. I'll get rid of the resistors though and use the new flasher instead. LEDMod's switchback for 2011+ looks cool, but it seems like the white light is brighter than the blinker's yellow light (which sounds right from what I've seen on other colored vs white LED bulbs). They should have made more of the LED SMDs for the blinker. I also don't drive around with my parking lights only on. Like 5zero4, I'm picky too.
I saw a thread on a Scion iQ forum that said that the replacement relay can't handle the load.
Second the replacement relay like the one someone on here used wont mention names is not a good idea it is really only designed to hold the load of two led bulb changes. In all reality it really is not a good idea to run mixed bulbs led/standard filament bulbs on these relays, they are intended for a 150 w max in actuality we need a combined load of 200w so it may work for a while but eventually it will fail, and you will have to take your dash back apart. For this reason I have decided to go the route of adding a 50w resistor to each bulb conversion.
LED Turn Signal Bulb Resistor Install - Page 2
I replied there basically saying that sounds like bunk unless your LED replacements actually use more power. Right?
Discussion Starter #11
Thanks! BrickPig to the rescue again. By the way your LEDs everywhere are awesome. Great electrical work.
I've had my flasher running two pairs of led strip taillights per side in the rear with stock filament bulbs up front, all four stock filament bulbs, and currently one pair of strip taillights in the rear with stock front bulbs. All with no issue at all.
The one thing you have to adjust to is that it takes an extra 1/4-1/2 second for the bulbs to start flashing, so signal before changing lanes.
Discussion Starter #13
Ok thanks, Greg, good to know. I'll report back once I get everything and try out the all-4 LED blinker replacements with new flasher.
Question about the delay when turning on your turn signals... with the flasher relay you'll get a a second delay till it turns back to white. When you don't have the flasher relay you'll get one side that will turn white and the other side will be turned off. Same when you first turn on your parking lights you'll get a slight delay before they turn on.
Every time I turn on my headlights, I do the parking lights first to make sure they turn on then my HID's.
Flasher relay is the way to go. LED Mod had the right bulbs for me. I had aftermarket switchbacks bulbs before and they didn't work with the flasher relay cause of how the bulbs were made. I have switched my rear tail lights to led bulbs yet.
Discussion Starter #15
Ok, I have to report back with my success now that I have a minute, I haven't been on here for a while. I confirmed the replacement flasher relays work perfectly in my 2012.
I got this one from Amazon/iJDMTOY
Amazon.com: 8-Pin Flashing Speed Adjustable Electronic LED Flasher Assy Relay Fix For Lexus Scion Toyota LED Turn Signal Light Bulbs: Automotive
It's the adjustable one, but they have the regular one too. I figured I'd get that one so that I don't get stuck with a blink rate I don't like or something. It works as advertised. Once I got the hang of removing the plastic panel it was pretty easy.
So I went to DiodeDynamics and swapped the backup light LEDs I got that I didn't like for another set of blinker LEDs for the rear blinkers - I was pretty happy with the front ones and I decided not to go with switchbacks for various reasons.
When I got the chance, I installed the new rear blinker LEDs. They hyperblinked of course. So then I swapped out the flasher I mentioned above - took a little finger wrenching in a tight spot. Problem solved! Adjustable blink, lol. At that point I pulled out the resistors (and my nice mounting and electrical tape job) I had put in for the front blinkers. Thankfully they were little splicer things that didn't actually cut the wire - big help. Everything worked great, and no hot resistors. So I have 4 11watt LED blinker bulbs running on that flasher. Now the replacement flasher says max 150 watt so you might have to watch it if you go really bright. DiodeDynamics for instance has an 80 watt option for their brightest blinker LEDs so you'd be going over the limit with just two of those.
I kept up with the DiodeDynamics guys and said I'd let them know how it goes, so I told them about the success and they said thanks and they'd pass it on. Hopefully they update their product for the 2011+ xB now to allow for the flasher option.
I really like the instant-on-off of these, probably like any LEDs and like the side mirror markers. Also, you don't see the yellow "egg yolk" there anymore so especially for the front of the car it looks cleaner, more silver and clear. I really didn't think I'd care about that at first but I do notice it now. There is a slight delay when you flip the blinker - the blinkers light immediately, but the first blink is slightly longer, no big deal at all. The LEDs I got are subjectively maybe 50% brighter than stock. They stick out further into the reflector housing so they probably don't reflect as nicely as the little bulbs did, but the brightness more than makes up for it. Plus there is a projector over the LEDs on the end of the thing which definitely helps.
Next up, brake light LEDs probably, hehe. Instant on/off will be good for those.
Quick videos-
LED front blinker, 2012 Scion xB - YouTube
LED Front Blinkers, 2012 Scion xB - YouTube
Stock Front Blinker, 2012 Scion xB - YouTube
Stock vs. LED Front Blinkers, 2012 Scion xB - YouTube
Pics
Discussion Starter #17
Hey thanks.
Actually, funny you say that, I just got some LEDs for the parking lights from Amazon iJDMTOY, here-
Here these are probably the same ones on the actual iJDMTOY site-
168 194 2825 2W High Power LED Bulbs For License Plate, Interior Lights
They don't say the color temp, just Xenon White.
I have some pictures too so I'll post to show you and you can make your own judgement. This is with my stock headlights. For the beginning pictures, passenger side is with LED parking light, driver side is stock. I took them back out for now since they looked so different. They are a great brightness though, they won't overshadow my blinkers.
Here you go!
Discussion Starter #19
Looks like what I've got already. I might try some warm white ones to see if it's closer.
Ok, so these are too blue for 5000K HIDs? Good to know. I'm thinking 5000K myself on HIDs (whiter than stock but not bluish I hope, hopefully still plenty bright). How do you like them? Do you have any photos somewhere?
1 - 20 of 28 Posts
