21 - 28 of 28 Posts
Discussion Starter #21
Not a very good example as they look pretty close in this photo. They look more like my drl color in person.http://www.autoguide.com/mobile
Ok cool, thanks for the pic! I can see a bit of blue coming off the top of the one on the left in that picture, and not from the headlights, so I see what you mean. Good shot of your DRLs there, might have to do that :wink: Now we only need a reliable color temp on everything out there.
I'm actually thinking of doing something different for my drl's. So if anyone wants to trade me their stock cheek inserts plus $20 let me know. I have used 3w 6000k eagle eye LEDs. They are super bright but look more like 7000k, so too blue for my liking. But if that's what you have in your headlights they would look perfect.
Sent from AutoGuide.com App
Ok, I have to report back with my success now that I have a minute, I haven't been on here for a while. I confirmed the replacement flasher relays work perfectly in my 2012.
I got this one from Amazon/iJDMTOY
Amazon.com: 8-Pin Flashing Speed Adjustable Electronic LED Flasher Assy Relay Fix For Lexus Scion Toyota LED Turn Signal Light Bulbs: Automotive
It's the adjustable one, but they have the regular one too. I figured I'd get that one so that I don't get stuck with a blink rate I don't like or something. It works as advertised. Once I got the hang of removing the plastic panel it was pretty easy.
So I went to DiodeDynamics and swapped the backup light LEDs I got that I didn't like for another set of blinker LEDs for the rear blinkers - I was pretty happy with the front ones and I decided not to go with switchbacks for various reasons.
When I got the chance, I installed the new rear blinker LEDs. They hyperblinked of course. So then I swapped out the flasher I mentioned above - took a little finger wrenching in a tight spot. Problem solved! Adjustable blink, lol. At that point I pulled out the resistors (and my nice mounting and electrical tape job) I had put in for the front blinkers. Thankfully they were little splicer things that didn't actually cut the wire - big help. Everything worked great, and no hot resistors. So I have 4 11watt LED blinker bulbs running on that flasher. Now the replacement flasher says max 150 watt so you might have to watch it if you go really bright. DiodeDynamics for instance has an 80 watt option for their brightest blinker LEDs so you'd be going over the limit with just two of those.
I kept up with the DiodeDynamics guys and said I'd let them know how it goes, so I told them about the success and they said thanks and they'd pass it on. Hopefully they update their product for the 2011+ xB now to allow for the flasher option.
I really like the instant-on-off of these, probably like any LEDs and like the side mirror markers. Also, you don't see the yellow "egg yolk" there anymore so especially for the front of the car it looks cleaner, more silver and clear. I really didn't think I'd care about that at first but I do notice it now. There is a slight delay when you flip the blinker - the blinkers light immediately, but the first blink is slightly longer, no big deal at all. The LEDs I got are subjectively maybe 50% brighter than stock. They stick out further into the reflector housing so they probably don't reflect as nicely as the little bulbs did, but the brightness more than makes up for it. Plus there is a projector over the LEDs on the end of the thing which definitely helps.
Next up, brake light LEDs probably, hehe. Instant on/off will be good for those.
Thank you @hikingmike. Your posts help me move forward with my lighting project. I also used Diode Dynamics but they were still reluctant to commit to a flasher module working on the '15 xB. They were thinking there was some sort of internal computer running the tun signals now. I located and pulled my flasher module like you showed and it is still the same as yours. I ended up using a TapTurn module I had seen on an FR-S forum (still the same one). I'm totally geeked by this little thing. It's like 10x the cost of a regular one but worth every penny. It does what a regular LED flasher module does but better (no delays, adds tap function...) and an endless list of other crap it can do.
Here is a link to their page in case anyone is interested.
Also, here is a guy that does a pretty good video with his WRX.
https://www.youtube.com/watch?feature=player_embedded&v=K2nEDw1TDzk&x-yt-ts=1422503916&x-yt-cl=85027636
I'll try to put a video together and come back to post it but for now, here is my new LED and HID. I replaced every light I could, inside and out.
That's a nice module. Now why couldn't I have known about this last week when I had to order a new flasher module. :(
Don't beat yourself up. It wasn't really advertised for our box because they didn't know it would work. I've spoke to the manufacturer and they said they would add us to the list. It's not a very expensive mod either way. Run with the one you got for a while until the burning desire to have one of these overtakes you...
Discussion Starter #27
Looking great! I'm glad my posts helped. Interesting about Diode Dynamics.
Ha, those strobe things are neat. How do you trigger the different modes?
The one-touch lane-change sequence is kind of cool. My wife's last MINI had that.
By the way, I just replaced my taillight/brake light bulbs with LEDs from Philips. Philips is finally coming out with replacement LED bulbs so we have an actual big name manufacturer to go with if we want. I decided to go with them because they are smaller and better designed to work with the reflector housing, and they're also cheaper than the other options I had. So far so good. I took photos and they may be just a hair less bright than stock, but they looked the same brightness just looking at them. The resulting color is actually slightly more red (so less pink), but very similar. I decided it was better to go with something that works with the reflector housing better than something that's just brighter for the brake lights. $30 for a pair beats the LED prices for ones that are at least as bright. The option at Diode Dynamics that is slightly brighter than stock, the 11 watt HP11, is $60/pair.
News article about their release - Philips Vision LEDs Guaranteed To Deliver Dynamic Lighting For 12 Years: aftermarket News
Xenon Depot store listing - 7443 LED Philips Bulb | W21/5W LED bulb | Philips 7443 Vision bulb
It looks like Philips has these new design Vision LEDs for a lot of bulb types, but not our turn signals (maybe just because of color since they do have 7440).
Philips Vision LEDs – 12+ year lifetime
Philips bulb lookup
Philips Bulb Look-up
For 2012 xB-
Philips Bulb Look-up | 2012 SCION xB
The different modes are triggered by combinations of turn signal stalk position and the hazards button. It can be changed to function several different ways. Reprogramming instructions it came with are very simple.
Awesome to here about the Phillips LED's. I've always been a fan of their quality.
21 - 28 of 28 Posts
