1 - 10 of 10 Posts
will i rub with this combo???
I've got 235/45R17 and Hotchkis and I don't rub, you should be alright if i'm not mistaken.
According to: http://www.newscionxb.com/133-wheels-tires/3887-eddnogs-xb-2-0-wheel-tire-chart.html
225/45/17 is VERY close to "stock" overall/rolling size. That keeps the speedo, odometer, and the ECU all working like they are supposed to.
The width fits fine w/ the right offset range. I'm running 225/50/16 (SAME tread width and stock overall diameter as 25/50/17) on 7 inch wide rims. They are 38 offset and work perfectly. For 7.5 or 8 inch wide, go w/ closer to 35 or so and will all fit whatever your spring drop.
Wider bigger or larger overall diameter bigger?
unsure of the offset but i know its a 7.5 wide. but i hope it works out good just hope i can afford the springs now lol. do they work well with stock struts?
thanks
1 - 10 of 10 Posts
