1 - 8 of 8 Posts
I need to replace my tires and want to go beefy. I have been searching for a while. I know the 225 50 16 works well. I want to go larger either 225 55 16 or 225 60 16 .Im looking for others who are running these sizes and looking for pics. My xb is an 08 on stock springs. Thanks
I'm running 205/65r16 (not by choice) on prokit springs. 225/60r16 will b almost identical height but just wider. Here is a side pic. Let me know if it helps!
Yes this does help!:) Thanks! So if your lowered and have no clearance issues I should definitely not have a problem since Im staying at stock height.
I'm running 225/50 x 16 Yokohama S Drive summer tires on 7" wide Drag 34 rims with 40mm offset, I'm on NF210 springs. No clearance issues.
Sounds like you know this already, but for those who don't: according to Custom rims, wheel tire packages for your ride - RIMSnTIRES.com the 225/55x16 will introduce a 3.5% speedometer/odometer error and the 225/60x16 will introduce a 7% error.
The 225/50x16 size has the exact same rolling diameter as stock.
You are right brick! It does affect you. When I am going 70 according to my speedo, I'm actually rolling at about 74. Keep that in mind. It won't always be a 4 mile increase as it's a percentage. But if you can live with that then they will fit without a problem whatsoever and give you a little bit more ground clearance too. Even with lowering springs I am at about the same height as stock xb's only level. If you like this look and comfort then definitely go for it. Just make mental notes of your speedo.
hello, I am also trying to put 225 60 16 on stock wheels, stock suspension. Will I have problems with rubbing if I have two more people with me in the car?
anyone with closeup pictures with 225 60 16 or 205 65 16
1 - 8 of 8 Posts
