Hey everyone, I have posted this topic on other sites but everyone is as stumped as I am. I was just wondering if this has happened to anyone else.
So a month ago i decide that I am going to change the lighting in my ac controls (On an 08 xb) and I successfully changed out my LED's. SO then i think to myself ok i want these ugly bulbs out too. So i get the neo wedge bulbs from super bright leds dot com as a replacement.
So then I turn on my lights to test my newly installed leds (they power on fine). For the neo wedge bulb, I test all 3 individually and they work. So then I install all 3 of the bulbs and they don't work. I have tried switching the sides (polarity) and nothing. Not even the bulb in my shift area works but I know for sure that the bulb didn't blow.
I was very cautious in testing each of them. Ive done this before on one of my other cars so this is not the first time I've attempted something this.
I am just trying to see if anyone else has come across this issue before i say screw it and take it to the dealer.
Here is a picture below. And just so you know everything under the two pictures at the bottom is pitch black in the shift area. As you can see in the main picture only the LED's are showing up. Oh also, my dimmer switch stopped working. I have tested every fuse (in the dash and under the hood). All of them were fine.
As you can see i have marked the dimmer box which is located in the fusebox under the hood to the right. Does this have a fuse in it? i haven't attempted to take the cover off to even find out (mainly because it seemed difficult to do so, so i just left it). The white box to the left is what I found under the dash in the shift area. This is where the harness plugs in for the light that lights the shift area. Im wondering if maybe something blew here? I dunno
I came across another forum where someone had the same exact issue but i never got a response from them as to if they ever fixed the problem.
