Just curious to know where some of you are mounting your amps? I'd like to find a small enough amp to mount under my driver seat but Im not finding any small amps that will support 600 watts @ 4ohms.. I have debated removing the rear seat but I cant find any pictures or what the space is between the shelf below the rear seat and floor. thanks for any input.
Don't have one in my 2011 but in my 08 I had it under the passenger seat! Fit perfect
Just a cheap dual 400 watt to power my c-pillar 6x9s it was kinda nice though cause it had a rugged outer shell so I didn't have to worry about people kicking it!
Mine are under the front seats too. I have a 4-channel under the driver's seat and mono under the passenger seat. I wanted to put them under the rear seat, but there wasn't enough clearance without cutting out the bottom of the plastic tray - which I didn't want to do. I don't have 600W amps though either (assuming you're talking continuous not peak power).
Audiosavings.com has some cheap half decent stuff. Just gotta make sure you search cea compliant amps other wise you get some garbage. Mine is under my rear seat but I didn't mind having to trim the back of the plastic tray under there to get it in there
hey man thanks just bought an amp on there. Looking for a cheap box now till I find time to do some fiberglass again.
