I have read a lot of the posts on the subject of the back up lights on xB2's (08thru 10). The problem I think is that there not enough lite and it's not spread out . After seeing the possibility of adding some LEDs, how 'bout installing two flat square ones on each side of the rear tag (using 3M tape). I've noticed some cars with that config. and it isn't that bad looking. The only problem might be routing the wire form the original b/u lite up to the rear hatch. I'm going to do some more looking to see if I can find some the right size,total shape and bright enough. Any thoughts?
