HAHAHAHAHATartanJack said:What Phobic said . . .
Body kilts are looks, for the most part. Some are tailored for very high speed downforce and stability and airflow cooling around a seriously hopped-up engine, but most (the vast, vast majority) are just for looks. Besides, very few of us go fast enough for even the speed-designed kits to actually DO anything . . . (I'm not sure a stock xB CAN go fast enough for much difference).
There are kits that can make your box have louder wind-noise on the interstate, just make sure there aren't pockets w/o outlets or elements that would make the wind have whistling noises generated by airflow around them.
For handling, the only issue would be a badly designed kit dragging the pavement when cornering, hitting the rims, interfering w/ the suspension, or being heavy enough to screw-up the balance. Suspension and wheels have MUCH more effect on handling.
Now, 16 inch rims can look good w/ any body kit, as long as they fit the style of the kit. It is more a matter of complimentary style and colors. Some will insist larger wheels are necessary, but it is really more of a cosmetic thing.
I'm planning on keeping w/ 16" rims myself, more for weight issues (lighter is better) and to keep the 50-series sidewalls of 225/50/16 rubber (which fits on 6"-8" wide rims). I'm running those on my steelies right now. More sidewalls help have less roughness on the crappy asphalt called "roads" in the Carolinas . . . (absorb small bumps and so forth so the shock/struts/springs don't have to)
Ooops . . .ocotillo said:HAHAHAHAHATartanJack said:What Phobic said . . .
