My 2010 xb is making a clunking popping noise every morning when I back out of my garage and then again when I back onto the street. It is odd I also notice it lightly when driving and hitting certain kid of bumps or large cracks in the road. Anyone experience this before? I have nf210's and a strut bar. its really annoying, but it is not all the time.
Double check the 3 nuts on the shock tower are tight. If I remember correctly, the torque is 35 ft. lb.
The 2 nuts for the strut brace on mine are 17mm and the stock one is 14mm...
I will double check it I did retighten them down after my strut bar I just pray its not the dang strut nut. Aside from that I will be stumped cause its not the brakes and nothing seems loose up front.
I had this in my last car a couple times caused by different things. I don't know how it compares to the setup our xBs, but they were caused by - loose front outer tie rod ends, and rear spring broken!
