M.I.L. "ON" DTC P0101, P0172, P035#, P2237 or P2238
Service
Category Engine/Hybrid System
Section Engine Control Market USA
Applicability
YEAR(S) MODEL(S) ADDITIONAL INFORMATION
2008 – 2009 xB VDS(s): KE50E
Introduction
Some 2008 – 2009 model year xB vehicles may exhibit a M.I.L. “ON” with one of the following
Diagnostic Trouble Codes (DTCs):
• P0101 – Mass Air Flow Circuit Range / Performance Issue
• P0172 – System Too Rich
• P035# – Ignition Coil “#” Primary / Secondary Circuit
• P2237 – Oxygen (A/F) Sensor Pumping Current Circuit / Open
• P2238 – Oxygen (A/F) Sensor Pumping Current Circuit Low
An improved engine wire harness has been developed and implemented in production to address this condition. Use the following repair procedure to diagnose and repair customer complaint vehicles.
Production Change Information
This TSB applies to vehicles produced BEFORE the Production Change Effective VINs shown below.
MODEL ENGINE DRIVETRAIN PRODUCTION CHANGE EFFECTIVE VIN
A/T JTLKE50E*91067111
xB 2AZ-FE
M/T JTLKE50E*91067112
Parts Information
PREVIOUS PART NUMBER CURRENT PART NUMBER DRIVETRAIN PART NAME QTY
82121-12J10 Same A/T 1
82121-12J00 Same M/T Wire, Engine 1
© 2008 Toyota Motor Sales, USA Page 1 of 3
S-SB-0050-08 November 12, 2008 Page 2 of 3
Warranty Information
OP CODE DESCRIPTION TIME OFP T1 T2
EL8055 R & R Engine Wiring Harness 2.5 82121-12J#0 8A 73
APPLICABLE WARRANTY
• This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for
36 months or 36,000 miles, whichever occurs first, from the vehicle’s in-service date.
• Warranty application is limited to correction of a problem based upon a customer’s specific complaint.
Required Tools & Equipment
REQUIRED EQUIPMENT SUPPLIER PART NUMBER QTY
TIS Techstream*
NOTE: Software version 4.00.017 or later is required.
ADE TSPKG1 1
* Essential SST.
NOTE: Additional TIS Techstream units may be ordered by calling Approved Dealer Equipment (ADE) at 1-800-368-6787.
Repair Procedure
1. Using TIS Techstream, check for stored DTCs.
2. Verify one of the following DTCs is present.
• P0101
• P0172
• P035#
• P2237
• P2238
NOTE: If other DTCs are present along with any of the DTCs listed above, this TSB does NOT apply.
Follow Repair Manual procedures to diagnose those DTCs.
S-SB-0050-08 November 12, 2008 Page 3 of 3
Repair Procedure (Continued)
3. Follow Repair Manual procedure to inspect the DTC-related component(s).
Refer to the Technical Information System (TIS), applicable model year Scion xB Repair Manual:
• P0101: 2008 / 2009 Scion xB:
Engine/Hybrid System – Engine Control – “2AZ-FE Engine Control System: SFI System:
P0101: Mass Air Flow Circuit Range / Performance Problem”
• P0172: 2008 / 2009 Scion xB:
P0171: System Too Lean (Bank 1)” (P0172: System Too Rich [Bank 1])
• P0351/P0352/P0353/P0354: 2008 / 2009 Scion xB:
P0351: Ignition Coil A Primary / Secondary Circuit”
• P2237/P2238: 2008 / 2009 Scion xB:
P2237: Oxygen (A/F) Sensor Pumping Current Circuit / Open (Bank 1 Sensor 1)”
(P2238: Oxygen (A/F) Sensor Pumping Circuit Low”)
4. If the DTC-related component(s) is within Repair Manual specifications, replace the engine
wire harness.
5. After replacing the engine harness, clear DTCs and verify that no DTCs reset. Then warm
vehicle to operating temperature and test drive to verify repair.
