1 - 11 of 11 Posts
Hey guys im new to the forum.
Here's my issue. Im trying to pull the badges off my 2008 xb. I got the "xb" one off but no matter what the "scion" one won't come off. Ive used dental floss/WD-40/a heat gun and the thing wont budge. Any suggestions?
Thanks for all your help
I got a 5-in-1 tool, wrapped it with a cloth, hosed the badge with goo gone and a hair dryer, and just started prying. there are holes there, though so if you take it off, those will be exposed.
The rear is held on by the gray sticky gunk , so dental floss slices right through that. What your hitting is one or both of the 2 posts used to position the emblem. One is in the upper part and one to one side. If you look hard, the holes the posts go into can be seen here:
Image pirated from somewhere, but forgot-? so can't credit. I grabbed it for personal reference, but find it VERY helpful to illustrate the door holes on the hatch.
I used fishing line. I went at it from every direction until I hit the posts. Then I was able to gently pry it up the rest of the way.
I capped mine w/ silver vinyl I had laying around.
I just painted mine then put them back on = no holes :D
More of a re-badge than a de-badge.
1 - 11 of 11 Posts
