1 - 13 of 13 Posts
Good day all. Ok so I have searched all over and I just need a definitive answer. Originally I was going to go with nf's but the more I read I am going to go with DF's and hotchkis sways.. A) Do I need to upgrade my shocks and struts? B) Will I have an issue with rubbing at all? I am thinking of going with xxr 530 19x8.75. I can't seem to find the offset or backspacing. And I am not sure of the tire size I should run with it either. Yes I am a bit of a noob. only have the KN Typhoon, Fireball dual and tsudo headers installed so far. Any answers will help. Thanks all!!
I currently have DF210 and was running TC2 wheels 18x7.5 +39 all around only rubbing i had was on the fronts i would rub the wheel wall splash guard in the rear i needed a spacer to make them flush (never did it)
Which rims were you rubbing with? Front or rear rubbage? And what does the 40et mean? I guess what I am looking for is to be flush as possible and big as possible without rubbing. If I need to roll my fenders so be it...
Thanks guys!
I ran DFs with 18x7.5 40et and also had 17x8.5 17x9.5 staggered, not sure the offset. and there was some rubbing but it wasn't bad.
they are def my favorite springs.
and you wont need new struts or shocks, use the stocks. thats what I did.
same here ..love ther springs but had to let them go to a new home.
I assume 2008 2009 are the same as 2012 and will fit?
Discussion Starter · #12 ·
Perfect!! Thanks!! Ordered....
1 - 13 of 13 Posts
