1 - 20 of 23 Posts
Here is a quick write up on how to do it your self along with the pics
First you need to jack the rear of the xB and support it in jack stands. Then you will need a 14mm socket and rachet. You will want a long extension also. First take the front two 14mm bolts out of the B pipe upfront. Let it kind hang there. Then take the 2 14mm bolts out of the rear of the B pipe. The hanger will still be holding the B pipe in there. Then pull the b pipe off the rubber hanger. You will need the rubber hanger peice for the strup B pipe as well. I took the old B pipe out and put the hanger off it and put it on the new Strup B pipe. Then put the new B pipe in there. Make sure you slide the back of the B pipe over the axle and then slide the hanger back on. I put the 2 14mm front bolts back in barely. Just mainly there to hold the pipe in its spot.
Then go back and slide the actual muffler section off the hanger as well. The exhaust should be out of there now. Take the rubber hanger off the stock muffler and put it on the Strup peice. Now take the Strup muffler section and hang it under the xB by the rubber hanger. Both peices should be in there now. They will be loose but that is ok.
Take the gasket that is supplied and one of the bolts and line it up and put one of the 3 bolts in the rear peice. Make sure that you are not smashing or bending the gasket in any way. Now take the remainder of the 2 bolts and get it all put together. Make sure that you tighten all 3 bolts in place. This is where the extension comes handy. Now go back up where you left the 2 bolts in the front of the B pipe loose and tighten them up. Make sure everything is tight and not hitting anywhere. I just grabbed the exhaust and shook it and it didnt hit anywhere. Now you should be able to start the xB and check for leaks.
This took me about a hour total and that was with getting everything jacked up and set to do the work. I hope this helps out.
You can buy the exhaust off my website. I do sell them as well.
http://www.nolimitzind.com/exhaustxb08.html
very good write-up. looks very nice. have you noticed any power gains?
yeah it did help for sure. I did this a while back. But forgot I did the write up on it. Figured some people here might be able to use it.
is it ok to use the TRD CAI and this product? I am looking into getting this exhaust but I dont know if they would work great together. I know slly question.
As they work on different parts of the engine flow system, that isn't a problem. They don't touch and stock is between them. I'd extend that to the header too.
Just for comparison of tip size:
yea i think im getting this! i have the Magnaflow... and as it turns out it hits the spring when i hit a bump, and its because it sits lower than the strup! i just figured it out by looking at the pics! just wanna know if sound is good because youtube lies!
Youtube does lie. Mainly because everyone uses cheap "point and shoot cameras". Once I get the HKS on, I will make a video with my D90. I am not too sure on the sound quality but a $900 DSLR should be able to pic up sound better. If not, then it is time for an upgrade.
Tar, can you feel a difference in power? How loud is it in the cabin area? Video of a drive by and not just sitting still?
See... I want this... but now I don't know whether to get this or the HKS! **** my indesiciveness! (Spelling :/ ) should have seen me when I was car shoping. Took me 3 months.
Its cool got the Magnaflow fixed. Apparently wasn't tight enough. Still not loud enough... but eh ill wait.
1 - 20 of 23 Posts
