If it the 2008 Scion xB base head unit it does not, I cannot speak for the other years however its only about 5 minutes to get it out and look. Pull the oval bezzel cover off and you will see the screws and bam pull it out enough to look behind to get your answer, wam bam thank you mam.
The PT546-00080 is the 08-09 base unit.
Thanks, Plan B.  I thought you'd know.
Wam Bam the Man is correct.
i ended up checking up removing the head unit out to check it out like plan B said ...it doesn't have any...fortunately i will replace it with a Pioneer AVIC 120bt along with 4 kenwood type r  and 2 12"  Kicker CVR
