SLR MOTORSPORTS GAS SAVER CHIP SCION XB 2004-2010
The SLR Motorsports Gas Saver Chip can save you 7-10+ MPG and you can still gain 40+ HP at the same time! With our revolutionary Gas Saver Chip installed, you will find yourself amazed at how much MPG you really can save. Each Gas saver chip is programmed with software to recognize your engine size for your exact vehicle and then adjust accordingly. The SLR chip will read your vehicle's computer system to determine which tune to select to run perfectly on your vehicle. The best part about our products, is that your factory warranty will not be affected in any way! Its impossible to save fuel and gain HP at the same time. Therefore when your cruising, the SLR chip will help you to save fuel. Then when you want that extra power, you accelerate and you are instantly thrown back in your seat. Basically, with the Gas saver chip installed when your vehicle is under 3500RPMS you will be saving fuel. Anytime you go over 3500RPMS the SLR Gas Saver chip modifies the vehicles fuel curves to unleash that hidden horsepower. We also offer a performance chip that is guaranteed to give you 50+ HP, 50+ TQ and 3-6+ MPG.
