I'm looking to get some of the factory style driving lights for my xB does anyone know if there all pre wired for them or not?
In my opinion the OEM wiring is a bit light (wires seem thin). I'm pretty sure the OEM fog lights are 35 watts so if your new lights are also 35 watts each you might be OK. My old school fogs are 55 watts each, so I added an aftermarket relay, just to be safe.I ordered some OEM look a like ones and was hoping to have the OEM wiring to work with..
just a heads up, i remember reading in the manual to not install a hitch on an xb. Not sure why, something about not being designed for the load
Thank you both for the info, I don't want to pull a trailer with it I have one of those racks for putting a cooler and stuff on from my truck I want to be able to use with it....True, Mach..... They say not rated to haul a load over 700 lb's (or something like that) and the transmission cannot handle any type of trailer. However, I believe a hitch so you can add a bike rack or something very light is quite acceptable, as long as you do not exceed the loaded maximum capacity.
It is in the manual and should be your source for the actual numbers. 700 lbs may be a little high or low....
Dude that would be awesome, let me know I'll send you my address and gladly pay you for the shippingIf I can find a box the hitch is yours. I want this crap gone.
