1 - 3 of 3 Posts
fitment questions advans 17x9 n 17/9.9 offset 29/22
sorry, but i need some help with this fitment-
advans
17x9 195/40 offset 29
17x9.5 225/40 offset 22
will this fit on a 2nd gen xb dropped on tanabe nf210?
anyone running this set up?
A 195mm wide tire is going to be *really* stretched when mounted to a 9" wide rim (if you can even get it mounted). Also a 195/40 x 17 tire is a lot smaller than the stock 205/55 x 16 tire, which will introduce a lot of speedometer/odometer error and wheel/fender gap.
I'd advise against this setup. Instead you should look the Size Comparer tool at
Click on Shop Rims by Car, enter your car data, then click on Size Comparer to play with various wheel and tire setups.
With NFs you won't even come close to those rubbing or hitting but you will have some substantial wheel gap with such a smaller diameter tire than stock. The tires you are looking at are about an inch smaller in diameter than stock so you will be gaining 1/2" more wheel gap than you have now. As for the stretch, you can do it but there is no reason as you aren't doing it for clearance issues with those offsets and your drop.
1 - 3 of 3 Posts
