1 - 4 of 4 Posts
I'm not Pimping this Product but asking if anyone here has tried it and/or installed it yourself.
Paint Protection Film Kit Precut Deluxe Adhesive Clear Bra Scion XB 2012 | eBay
I Watched a couple of videos on some graphic and they Use Foam Glass Cleaner under the Graphic (lots ) and I would think it would have bad effects on the Paint in the future. Just doesn't look Kosher to me all that foam under the stickers. :book::help:
I installed the top ones (hood front and above headlights). The install is a lot tougher than it looks in the videos. I've done window tint and vinyl wrap before but working with this stuff was harder. A second set of hands is a must. Mine came out almost perfect. After doing the easiest ones I decided not to do the bottom pieces, because of the curves, unless I can find a pro.
To install you'll need water/vinegar mix and to dry water/alcohol mix in spray bottles, a few lint-free microfiber towels, squeegees, hair drier and some insulin syringes/needles (super fine tip). The needles help to remove any bubbles; you inject some alcohol into the bubble then suck it out and rub. Touch-up any paint chips before starting. A garage with no dust or breeze is a big help too.
It does work at protecting the paint and is almost invisible. I would recommend looking for 3M brand or OEM kits.
1 - 4 of 4 Posts
