1 - 1 of 1 Posts
This is for local pickup only
This is the sale of 2 Kicker Comp C124 12" 4 ohm woofers in a black carpeted box that has the angle on the back of the box for fitting up against seats in a trunk or hatchback. I am selling this for $100.00 firm with the box.
********This sale comes with one replacement warranty from Best Buy which is transferable. *********
These work excellent and play well and are in warranty with Best Buy. I have played them with proper power as I am a professional installer for the last 17 yrs.
The best balance between high value and high performance!
The famous Kicker Comp subwoofer provides excellent Kicker bass, while sticking to a tight budget. The Comp subwoofer has been redesigned for 2010 with looks that are stunning and technology that is time tested. Some of the engineering behind this subwoofer is the extremely rigid injection molded cone. The cone has been adjusted to match the 2010 Kicker line of subwoofer, but it still keeps it traditional black and yellow design that the Comp is known for. Behind the cone, the subwoofer features 360 degree back bracing, a vented pole piece, Kickers Spiralead tinsel leads, and a sturdy steel basket. This legendary Comp subwoofer from Kicker is the perfect balance between high value and high performance!
A 12" Kicker Comp subwoofer is the most common size of subwoofer purchased and installed into a vehicle. These 12" subwoofer provide top-notch response when playing at low frequencies. The size of the cone and structure make it perfect for most applications and the perfect size for accurate bass.
Size (IN.,CM) 15, 38.0
Impedance (OHMS) 4
Max Rec Amplifier Power (WATTS PEAK/RMS)* 500/250
Sensitivity (dB 1w/1m) 90.3
Frequency Response (Hz) 25-500
Mounting Depth (IN.,CM) 7 7/16, 18.9
Mounting Cutout (IN.,CM) 13 11/16, 34.7
Injection molded SoloKon cone
Optimized Polyfoam Ribbed Surround
Extremely rigid cone, along with 360 degree back bracing eliminates distortion
Double stitched surround for enhanced durability
Tinsel leads woven into the spider with Kicker's Spiralead technology
Single high-temperature voice coil
45oz. Magnet structure
Frequency response: 27-500 Hz
The box is made of MDF and is professionally made and carpeted in black. This woofers are a current model and sell for $79.95 EACH on top websites and for $119.00 each at local stores not including the box.
I have 2 of these boxes available, but this one is with the Best Buy replacement warranty.
This is the sale of one box with 2 woofers
for the pix hit the craigslist ad
Kicker Comp C124 12" 4 ohm woofers w/Box
The reason i'm sellin?
Just bought 2 Earthquake Tremor X 154 15" spl woofers
1 - 1 of 1 Posts
