I'm not impressed by the amount of light that the factory backup lights produce, so.......
I'm going to pop out the two rear reflectors out of the ground effects and use a hole saw to cut openings for two more reverse lights. I am going to have to locate a suitable diameter white light (Hopefully with a fluted lens) and then run a primary wire from the battery with a relay triggered off of the existing backup lights.
