1 - 11 of 11 Posts
I am thinking about installing a Grounding Kit in the Engine Bay. If anyone has done this...
1) Did you notice a performance and/or mpg gain after doing it?
2) Where did you attach the ground points?
i have a home made one on my box.. made it out of 4 gauge wire and ground connectors .. i noticed allot of change.. brighter lights... steady idle...my sound system is louder.. you should try it out.. you can make it or buy it either way you are making a good decision.. as for grounding points i actually rigged up the positive of a led to my battery and just tried out allot of size ten bolts in my engine bay to see if it was a good ground.. if the led lit up i connected it there.. hope this helps
Effectiveness is dependent on the stock wiring system design. One thing to keep in mind in Scions in general and xB2s in particular: they are designed to be modified. So, some stuff is actually overkill for stock. The brakes are designed to provide a "normal" feel for 20" rims, so they are really more than needed in stock form (and make no need for the "big brake kit" when running light rims). In fact, the reason stock steelies are 16" is that those are the smallest rims that fit over the stock brakes. The suspension also "upgrades" very easily too. As rims and stereos are the 2 primary mod-areas for Scions, I'd be surprised if overkill grounding wires weren't used originally- thus allowing for amps and so forth to be well supported w/o extra grounding wires or a larger alternator.
1 - 11 of 11 Posts
