1 - 2 of 2 Posts
I really want halo projector headlights for my 2008 scion xb but im not sure of the best way to do this. Please help, will rep. I have seen some pre-made kits by spec-d but i haven't read good things about them. I have also heard of people doing them custom. I don't know how this would be done, but I will do it if someone can show me a post on it. Thanks a lot.
I haven't done it, but I think I can at least outline the process until someone with experience chimes in.
Pull the headlights off the car and separate the glass from the housing (bake or use a heat gun to soften the seal)
Install the halos around the projector lenses.
Drill a small hole in the back of the housing to run the halo wires. (Seal around the hole to make watertight.)
Seal the glass back on the headlight housing.
Wire it up.
BTW if it were me, while the headlights are apart, I'd also paint the inside of the headlights too. Search around and you will see write ups on that.
1 - 2 of 2 Posts
