21 - 29 of 29 Posts
Discussion Starter · #21 ·
okay, so i got the Strup race headers from santa. :)
I've been trying to install them but i keep running into problems. i've got the 5 bolts on the top off, the 2 spring bolts off, but found the 2 14mm bracket looking ones. any advice on getting them off?
Discussion Starter · #23 ·
I got my strup headers installed, but had to unbolt my dipstick, and I've been experiencing a lag whenever I step on the gas. Has anyone else experienced these problems?
Pics to follow
If it acts weird, unplug the battery, wait a bit (15 minutes or more) and replug. That should reset the ECU and it relearn the power band/curve w/ the header.
Discussion Starter · #27 ·
Well, I took my CEL eliminator off, and the lag went away. So, I guess that's a waste of money.
CEL eliminator is a must have you wont run well without it and the engine will go into limp mode. Make sure it is installed on the S- pipe section of the exhaust some people have made the mistake of attaching it to the a/f sensor attached on the header. The header should have come with the dip stick relocator which is basically a small aluminum piece and a nut and bolt that extends the dip stick enough as to not interfere with the header.
Discussion Starter · #29 ·
OHHH! thank you! I should have read the directions a little to see what that nut and bolt and aluminum piece was for. haha
21 - 29 of 29 Posts
