Can '11-13 utilize '08-'10 headlights? I know the only difference is the turn signal is a diff bulb, but is it so diff that it's not compatible?
Sent from AutoGuide.com App
dont pull on those. I pulled and cracked mine. there are tabs around the ball shape things that go into the tab. you gotta carefully pry the tab and try to remove them. I had to jb weld mine back together cuz I was getting frustratedFlex. How did you get the second chrome piece apart from the back of the headlight? The part that holds the projector in. I saw 2 ball joints but te second is so far back I can't reach it and I. Don't want to just pull and pray....
