I updated my factory horns on the 2009 xB with a pair of Hellas. Easy install and great fit. They were from a fairly late model Mercedes. Cost was $5 at the auto recycling center. Install took about an hour and they work great. Definitely a deeper tone and probably louder.
The Merc horns seem to be located right behind the grill on all of the cars that I looked at today. They are retained by one bolt, but they each have their own bracket. The horns are flat and only a bit larger in diameter than the Scion horns.
Unlike most horns that ground through the bracket, they need a ground wire. That is easily resolved by running the ground wire under the bolt on the install. I put both horns in the original locations and used the Scion bolts and wiring.
With the horn and some wiring odds and ends, I was in about $6 and some of my time this morning to pull the horns. All of the Mercs that I looked at still had their horns, and it appears that the same horns are used on all models.
Dick
Dick
