alright so i bought the paint on can from ace hardware and i have the pros and cons that i couldn't find online now.
plasti-dip feels and appears after it has dried like vinyl. it is absolutely the same color as the matte black vinyl that i used for my bumper so i said **** it an touched up the sides instead of taking off the vinyl.
the reason people use vinyl instead of plasti-dip, or at least from what i just experienced, is because plasti-dip is thick and once it contacts the surface it goops up and is lumpy. in small coatings it flattens out but in large quantities it looks like you tried to use play dough. i highly recommend using the spray can kind because that will leave an even coating that a foam paint brush just cant do. also when using tape to give it an even edge, immediately remove it after you have applied the dip. it adheres very quickly and unless you want to us a razor the tape has to go, it will hold it shape.
so in the future i will use the spray can and take the tape off immediately.
ill probably stick with vinyl for larger stuff and the dip for touch up
