Need help with the reverse tailight for a scion xb 2012, what is the size and watts recommended? I want to add leds is it 194 t10 work ? Thanks ahead of time for replies
The 2011 - 2013 XB uses a 912 bulb which uses the same base as a t10. Any t10 - t15 bulb will work. A heads up though, currenty manufactured LED bulbs are dimmer than a standard 912 bulb. Even the Cree led projector bulbs put out less light.
