1 - 20 of 30 Posts
long time troller first time posting...
ok so i have been searching for weeks and im a bit confused about hooking up hid fogs. my car doesn't have any fogs but i already running hid lows for my headlights on a relay harness.
i just received my universal h3 projector fog lights and just ordered an h3 hid kit for the fogs. my question is do i need to hook up a second relay harness to get my fogs to run hid? is it safe or ok to run 2 separate relay harnesses, or unnecessary? i dont plan on using a switch im going to just wire them to the headlights.
any input is greatly appreciated...
Discussion Starter · #2 ·
couple unrelated pics of my xb
If you use the same harness, the fogs will come on at the same time as the existing lights. Also, I don't know how much extra capacity the one harness has for 2 sets of lights. To be safe, I'd get another harness, they don't really cost that much more to have the extra protection.
ok so thats exactly the answer i was looking for... hook em up using a second relay harness, thank you!
and now i have no idea wheres a good place to mount the hid ballasts for the fogs, need some input guys
If I am just installing oem fogs is just plug and play no need for relay? I also have low beams hid no relay. I got a steal on new oem fogs for 2012
One set, it just plugs into the connectors already in the harness.
When your front bumper is off you will see space on the frame near the foam pad on each side to put them.
When your front bumper is off you will see space on the frame near the foa gotm pad on each side to put them.
yeah i found a large flat space under the headlight housing, it should work perfect...
well an update to my universal projector fog lights install, worked on this for 3 hours and i didnt get to start hooking up the hid wiring, but i did get the fogs installed...just not wired up yet because it got dark outside.
but let me know what you all think of my hack job. not the cleanest install but once wired should produce large amount of light, which was the whole point...
i think it looks sick! i havent seen anything like it on an xb2.5
Discussion Starter · #10 · (Edited)
so these are the fogs i got on amazon for $25 shipped. then added a 8000k 35w hid kit from opt7 also on amazon for 39.99 shipped. total cost for custom hid projection fogs for 64.99!! you cant beat that, kit also came with a relay harness.
side note ive been running these opt7 8000k hids on my low beams for 9 months.
Looks good! I got a set of ebay projector fog lights and the projectors themselves are just horrendous. They shoot light haphazardly all over the place. I was looking into getting a set of projectors like the ones you've got and retro them into the foglight housings, but I was wary of the output and if it had a clean cut-off line. Do you have any pictures of the fog light output?
I got a set of Opt7 Bolt HIDs for Christmas, but ended out returning them as there were numerous things wrong with the kit ranging from super loose bulbs to ballasts that flickered and blew fuses immediately. So back to the DDM kit that has been chugging along just fine.
Discussion Starter · #12 ·
didnt get them wired yet, it got dark outside and i began to get wife agro 3 hours into it lol
but as for opt7 i havent tried the bolt series but blitz series works well for me, ive been running them for 9 months, day and night...
I've gotta ask, the lights in your headlights are killer, what exactly are those? I know they're probably strips but what style?
Discussion Starter · #14 ·
Auto zone white side mounted led strips, cost $24.99 for a 2 pack
Discussion Starter · #15 · (Edited)
more pics
Discussion Starter · #16 ·
updated day time pics...
so today was the first time i could see my work in the daylight, i think it came out great. i had to work all day so i couldnt work on the hid wiring :( maybe on my next day off
Discussion Starter · #18 ·
yea im gunna hook em up to the battery via a relay harness...and u know how when u hid low beams on a relay how u only use one side of the factory headlight harness, well im gunna hook up the fog relay up to the unused factory plug on the lows. that way i dont have to cut or splice the factory wiring.
my next day off is tuesday so that will be when i wire them up. only thing i gotta mod is i need to extend to wiring on the relay harness in order for it to reach the passenger side factory headlight harness.
Discussion Starter · #19 ·
update!
ok good news, i got a day off to work on the xb.
i got the ballasts mounted and relay installed, everything wired up and running! the 8000k hid fogs match perfectly with my low beams. it looks so sick! but its daytime, the true test is at night time. so i can wait for it to get dark outside. because i still have make sure they are angled right and whatnot. never the less here are daytime pics and i couldnt be happier with only spending $64.99 for the entire project.
i know u guys wanna see night time pics but let me know what u think...
Discussion Starter · #20 ·
more pics, doesnt exactly show the cut off line for the fogs but shows a before and after. my wife was getting annoyed, so i just snapped some quick pics.
first pic is before fogs
second pic is after hid fog install
pics 3 and 4 are just night time pics
1 - 20 of 30 Posts
