1 - 10 of 10 Posts
Discussion Starter #1
I'm not sure about the quality of HID lights, there is tons of them on ebay,, does anyone has a good experiance ? any brand in particular ???
I saw the silvesrtar zxe from sylvania... kind of similar without the Hid balllast
any story to share ?? suggestions ?? opinions ???
Sincerely
Vito
Cheap HIDs are dangerous, annoying, and illegal almost everywhere. If you aren't replacing the entire light housings, don't do it. Expect a real HID conversion to cost several hundred at minimum, and it still probably won't be legal. An explanation here.
The zXe bulbs are decent in some applications, but they don't really look like HID, and they have a relatively short life expectancy.
Discussion Starter #4
I was under the impression our low beam projectors are the same as the hid ones in other toyotas?
I do not know about that
on ebay. there is defferent prices, from 40 to 150.......
I really do not want to make it ugly,
I read in other post..... that they use a mercedes HID lights ...... that sounds good..... but I do not know which lights and what modification it is need it
anyway.. I thank you for your help :wink:
My understanding is the halogen projector has a smaller focal point compared to a hid projector, so adding a plug and play style hid kit will cause hot spots, ideally a retrofit would be best but depends if you wanna spend $ or $$$...
I put HID in my projectors, a kit I got from eBay (I've purchased 7 or 8 kits from the same seller and brand over the years). Kit I bought is 55w Ballast, 5k color, plug and play, definately increases the light output and with the factory projectors it keeps the beams directed in a fashion not to blind others. My MR2 Spyder on the other hand, in the halogen headlamp setup is obnoxious, however, being the smallest spec on the street, I'd rather be annoying and seen than a monster truck obsticle. Just my .02c.....
1 - 10 of 10 Posts
