1 - 8 of 8 Posts
ok so i had the hids in the regular headlights but when i changed them to the spec d headlights i cant put them in because of the different wiring:confused:. is there anything i can do to hook up the hids again?
If the Spec Ds will fit the stock, which they should, you shouldn't have any problems. And x2 to what Phoboc said.
i can take pictures right now but this is what it looks like, where the original headlights would have the wires to the light bulb this one has like a rubber cap...
My Anzo's also have the Rubber Caps. You pull the rubber cap off and the bulb is behind it. You have to cut a hole in your rubber cap to pass the wires through and your HID's should have a rubber boot on the harness. That rubber boot will pop into the hole you cut to keep everything waterproof. My only problem is that the Anzo lights use a different low beam projector bulb than the OEM lights did, so I had to buy a different kit for them. If your new lights use a different bulb, move your H11 kit to your fogs lights!
ok sound good... thanx for the help, havent done any mods for awhile so im a little lost on the electrical things things in the car!:biggrin:
btw wat was that other kit you bougt because i think i might have the same problem with the light bulb...
1 - 8 of 8 Posts
