I just installed my overhead console and to do it you had to remove the light. It has several of the metal clips on each side that you just pry it out and it comes loose. The problem is you need something wide so you dont mark up the headliner. My suggestion is a putty knife against the headliner and a thinn flat blade screwdriver between the putty knife and the light. Then pry it apart and it pops loose. You can look under sparks instructions for how to install the console for instructions. I actually bought a set of trim tools wich are plastice mini pry bars from harbor freight to take mine apart.
