eviljack said:
Plus the lower profile adds more to handling then lower weight tires would. So if they are heavier its a give and take type thing.
Yep, your right, it is a balance between weight and grippy tires.
Note, my statement:
Also, heavier the wheels are, it CAN (not necessarily will, but can) affect suspension performance in cornering.
That said, a more "grippy" tire can overcome that fairly easily.
The challenge is to maximize grip, while minimizing weight.
That gets done different ways on racing cars, depending on performance parameters needed, desired, and achievable within the rules. In some cases, small rims with high side-walled racing tires are used, such as in autocross and some racing series. On a nice, smooth track, some race teams go for a very low ratio and ultralight (and VERY expensive) rims with racing tires, such as in the American LeMans Series.
In F1, the tires are set by rules, but massive grip is achieved (despite much effort to limit it) on small rims with tall sidewalls.
It all depends on needs, $$$, and what one's aims are.
Oh, and a LeMans style rim would be VERY rough and probably destroyed on a typical street drive, as they have little sidewall to cushion rough pavement breaks from hitting the rims themselves. Yet, they work fine on the track.
One of the things that surprised me on the xB2 is that the stock 16" rims are 55 ratio, which are the highest used by the high and ultra performance tires. So, great rubber is available for them.
The 17s use 45 ratio tires, which is the same stock street rubber for many supercars.
For a street car, it is a balance of ride, weight, looks, grip, and cost.
For me, it is the least weight rims I can afford that a GREAT tire can fit and not make it too rough for the crappy and under-maintained roads I must drive on (I live in a town in the middle of the woods).
In that case, 16s and 17s would work well. Until I find a "must have" rim I want, I'll just run my 16" steelies.
Oh, and (if you look) the steelies (at around 20 pounds) are LIGHTER than many aftermarket aluminum 16s and 17s. That automatically means I'm of very limited interest in those rims . . .
Some black Motegis I've seen are 18-19 pounds and look good (i like very simple wheels) . . . those might get a look!
-If only I could find some 16 pound 17s that I could afford and liked the looks . . .
