I have TRD springs, shocks, strut bar and rear sway bar installed. If it needs to be redone what values need to be changed and why.
Basically the more negative camber you have the better you can hold in the corners but at the expense of wearing the inside edge of the tire quicker. I had my fronts set at about 1* negative on the front for awhile when I was doing canyon runs twice a day for my commute but even that was wearing out the inside edge more than the outside. If I was to do it again I wouldn't go over -0.5*.I would like to adjust my alignment for high speed turning/cornering, what adjustments would you recommend making? I'm not looking for a crazy/extreme tweak, but the maximum adjustment within spec because it's a daily driver.
That's because without the shims it can't lol.The car is only 2 months old. I'm going to bring it back and see what they have to say. I'm expecting the "Oh, the rear can't be adjusted" answer.
Then you can tell them that you straight up don't want the car. :cheers:The car is only 2 months old. I'm going to bring it back and see what they have to say. I'm expecting the "Oh, the rear can't be adjusted" answer.
