1 - 4 of 4 Posts
Guys,
On my 2012 xB, I wanted to change daytime running light from yellow to white (something of the same color temperature as the low beam projector style). I did not want something that would look bluish. I have ordered Nokya 9005/HB3 65w (NOK7811). Color temperature is 3100K. You guys think it would look white enough? Whats the color temperature on the factory daytime running bulb?
4300 K is supposed to be white with lower numbers trending toward yellow and higher numbers towards the blue end of the spectrum
According to this from autoillumination.com you should be good.
Kelvin Color Scale
Color
Temperature Common Example
2000° Gaslight
2470° 15 watt incandescent bulb
2565° 60 watt incandescent bulb
2665° 100 watt incandescent bulb
2755° 500 watt incandescent bulb
2900° 500 watt Krypton bulb
3100° Projector type filament bulb
3250° Photo Flood
3400° Halogen
3900° Carbon arc
4200° Moonlight
4700° Industrial smog
5100° Hazy weather
5500° Sun 30° above horizon
6100° Sun 50° above horizon
6700° Electronic Flash
7400° Overcast sky
8300° Foggy weather
30,000° Blue sky
I ended up ordering 7411 which is 7000K. Now obviously 7000K is maximum it can go upto which would be when I turn high beam on. I'm not sure what wattage the DRL runs at. Hopefully it would look white in DRL mode otherwise I wasted $30.
1 - 4 of 4 Posts
