1 - 12 of 12 Posts
You got it...
Before:
After:
Before:
After:
Before:
After:
I also changed out the turn signal relay to an LED friendly model and yes, the plate bulbs were changed out to LED as well
and to head of the inevitable where did I get and what kind... here it is
Quantity: 1
Product: LED bulb Flasher Units $ 12.95 (each)
Options: CF18-08
Quantity: 2
Product: 7443-15 LED bulb $ 6.99 (each)
Options: Red
Quantity: 2
Product: 7440-15 LED bulb $ 6.99 (each)
Options: Red
Quantity: 1
Options: White 2.00
Quantity: 2
Product: 1157-A24 Amber LED bulb $ 7.29 (each)
Options: Wide
Quantity: 2
Product: WLED 6-LED bulb $ 2.79 (each)
Options: Cool White 0.95
Obtained it all from superbrightleds.com
As for the how to? Consult your Owners manual :yes:
Thanks for the pix and parts list, lvbitwiz. I was wondering if you needed to install any resistors to keep the bulb out indicators from acting up? Also, was there any reason why you didn't get the high output LED for the backup light?
Thanks again!
Here's a couple of pics that I took while I installed it just to give you an idea of what you're getting into if you DIY it. Keep in mind I followed the instructions provided **to the letter** , measured several times over and made plenty of tweaks to the templates until they were spot on. Measure twice cut one? nope, measure 500 times, centerpunch correctly and drill :eek: Oh yeah, and drill stops are a must if you dont want to risk damaging anything
setting the templates
after centerpunch
ready to drill :eek:
and 'dry' fit after drilling
The instructions http://www.trdsparks.com/install/PT921-52081-XXinst.pdf were very easy to follow and the templates werent plain ol paper, more like a printed mylar precut sheet. Most difficult part of the install was getting the templates set right, after that it's pretty much bolt/stick on
1 - 12 of 12 Posts
