1 - 6 of 6 Posts
Just a question about the rear of the hood vibrates at idle any suggestions on how to stop that? Love this car
Are you sure it's the hood or is the sound from the dash area? If it's a back corner of the hood I would suspect loose bolts on the hinge. If those are all tight, I can't see how the back of the hood would be able to vibrate. There is a known issue of the plastic cowl under the hood at the base of the windshield vibrating. Toyota fixed mine when it was relatively new. I think there is a TSB for it. They basically pulled the plastic cowl off and attached some adhesive foam to the bottom. You could use some thin weatherstripping.
Thanks Zinger for the reply, When I look thru the windshield you can see the back of the hood vibrating. I will try the weather strip on the plastic as that is what supports the back of the hood.
Hi Zinger, I did add some weather strip to the plastic and that helped some. I think maybe because of the high mileage and age of the car the rubber in the engine mounts may be hard it only does it when A/C is on.
I changed my front motor mount and it helped that vibration issue a lot! The factory rubber mount was dried out and was actually broken. The middle rubber part was no longer attached to the mount housing 😂. So the motor was vibrating like crazy
Congratulations- This is my second one ( I got side swiped by a eighteen wheeler in my first one) if you are interested HPS makes a short ram intake. Dynos at 7.1hp 8.4 torque. If you're into that.
1 - 6 of 6 Posts
