Got the throttle body yesterday.
Here it is next to a stock one.
Larger 65mm on the left, stock 55mm on the right
Biggest differences beside the obvious size.
Bolt pattern is different so if someone wanted to use this on the stock manifold it would need an adapter plate made.
The stock 55mm one has two extra vacuum attachments on it. One I've determined is for the EVAP purge solenoid, don't know on the other one yet. Simple enough to fix, just reroute them to another vacuum source or tap the new throttle body for it. The second of the vacuum attachments may actually be an input as it doesn't seem to go into the throat of the throttle body.
Last difference is the throttle plate screws, on the stock one the back of the screws have been flattened to make it impossible to remove them without damaging them. The 65mm screws on the other hand are normal and can be removed without damage. Makes it much easier to get the plate out for knife edging it.
