Hey everyone, I was just checking out the following lightweight aluminum crank pulley:
http://www.fastscions.com/Scion-Lightweight-Aluminum-Crank-Pulley-2AZFE-tC-xB.aspx
“These pullies are actually the same size as stock; however they weigh over 3.5lbs lighter than the OEM. By reducing rotating mass, this lightweight aluminum crank pulley gives the 2AZFE engines a gain of 5-6 horsepower and an increase in torque by 6-8+ ft/lbs.”
So it’s not actually an underdrive pulley, just a different lighter material to reduce the amount rotating mass driven by the crank. Even though 5-6hp is not a lot, I’m actually surprised it’s that much considering the pulley ratio is the same as stock. If that’s the case, I bet a lightweight flywheel/clutch assembly would also free up a few extra horses. Anyone talking about replacing their flywheel/clutch on manuals under this same principle?
