After doing some research,I finally ordered a set of mud guards off of ebay. That was Tuesday and I got them today from CA. I opened the box and not only were the items in there but there were even directions!
Tomorrow I will install the front ones it is supposed to a nice day.I've already dry fitted them and it seems that will go on allright.
I'll keep everyone posted.
Which ones did you get?
I've been thinking of getting a set, whenever finances improve.
Mud guards update
I got them off of ebay. They were around $65+ for all four and installed the front ones today( sat.) it took all of 15 min.s. You need a 10mm socket to take off the 3 bolts on the car on each side. The left side first, it took longer (learning curve) but it went fine.One thing though a screw and speed nut (supplied) have to be put on the underside just follow the directions a short phillips or a socket with a phillips head and rachet is needed there is no clearance for a standard driver. They fit great! Good quality although they are black. I'm shure one could get them painted but that might cause chipping later on.
mud guards
Post some pics. I've looking at getting those from ebay also. The oem ones are way too expensive.
Grammatical correction: ....I've been looking at getting....
