1 - 9 of 9 Posts
pop off thin on inside of car behind tail light, unscrew the 3 10mm bolts holding the tailing on. pull.
thats about it. there is a clip on the top, you'll see a green thing on the inside, dont touch it, just push on the back of the tailight and it will pop out.
How do you remove the screw that is at the very top. I can't access to it, some sheet of metal is blocking me from getting a good grip with the wrench.
Install instructions state you should be using a 10m socket not a wrench I remember using a socket with no problems.
Tail lights
basic remove and install. I am gonna by the Longo Scion tail lights. I wanted to see if anyone has done a write up on how to remove tail lights.
If you could do me a favor when you remove the tail lights, please notice if there is any space between the body and the bumper cover. I'm working on adding b/u lights to the outside of the light housings and need to know if I can run wires to the existing b/u light.
Thanks,Dale:)
It has been a while since I installed my LONGO tail lights....but, it was a good choice after going thru 2 sets of TYC tail lights. Removal and installation was easy as I remember...but too long ago to offer any advice.
Anyway :cheers: congrads on the LONGO(s)!
1 - 9 of 9 Posts
