I had Nightwerks Do my Dash This Weekend, Could not handle the Amber LED's any longer
Alfundo, did you just use blue LEDs or did you use some white as well? BTW, it looks great!did mine this weekend as well...
It turned out very nice. I bought a Black n Blue gauge face from Nightwerx. After seeing a lot of these conversions I think I will use white LEDs behind the gauges and blue behind the displays. Where did you get your LEDs from?Thanks! I just used blue leds in the digital display areas, i didnt change any in the dials as i am still using the OEM background. i also swapped out the turn signal leds.
Oznium.com ^
soldering, thats my thing. i build Circuit Boards for the company i work for. just LED light lmao. i can get pick up Leds at work.you can have your gauge cluster out in under 5 minutes...super easy! changing the leds requires soldering so if you can solder it is easy.
