Is it necessary to change the oil plug gasket, each time you do an oil change with your Scion xB?
They are SO cheap, that changing them isn't hard at all. I got a bunch for near nothing at the local dealership.
I just called the dealer, and the guy said it cost $2.99 for each one. :eek:
I just talked to one of my dealer's mechanic, that he said you DO NOT have to replace the oil plug gasket, each time you change oil. However, you have to check the gasket's condition each time you change your oil, do avoid leaks.
