Oil: Pennzoil Platinum 0W20
Oil Filter: OEM Toyota Filter
Air Filter: AFE Pro Dry S
Note: They accidently used the WRONG engine type for the universal averages (they used the old xB engine), but I did change to the proper values posted below. I did email them about this and they will probably fix it tomorrow for me with new information. However, that does change the comment section because my silicon will be only 2PPM over the average, compared to 5PPM before. Either way, VERY little wear. Excellent oil, oil filter, and air filter combo
Comments:
We are not sure how much silicon this oil starts out with, so we aren't sure whether the extra
silicon we found here is coming from the oil itself, or if it's from another harmless source, like leftover
sealers from when the engine was new. One thing we are sure of: it's not anything abrasive, because wear
looks terrific. The fuel is a common find in engines that see a lot of city driving and/or idling. We don't
consider fuel to be a problem until it reads above 2.0%. No antifreeze found. This Toyota engine is wearing
very well and should last you for years.
My Results / Average
ALUMINUM: ~~~~ 2 / 3
CHROMIUM: ~~~ 0 / 0
IRON: ~~~~~~~ 8 / 10
COPPER: ~~~~~ 1 / 2
LEAD: ~~~~~~~ 1 / 2
TIN: ~~~~~~~~~0 / 1
MOLYBDENUM:~ 55 / 90
NICKEL:~~~~~~ 0 / 0
MANGANESE:~~~ 0 / 0
SILVER: ~~~~~ 0 / 0
TITANIUM:~~~~ 0 / 0
POTASSIUM:~~ 0 / 1
BORON:~~~~~~~ 8 / 39
SILICON: ~~~~~19 / 17
SODIUM: ~~~~~4 / 14
CALCIUM: ~~~1993 / 2347
MAGNESIUM:~~ 10 / 121
PHOSPHORUS: 623 / 719
ZINC: ~~~~~~~~734 / 853
BARIUM: ~~~~~~ 1 / 0
Properties:
SUS Viscosity @ 210*F: ~~53.0 / 56-63
cSt Viscosity @ 100*C: ~~8.19 / 9.1-11.3
Flashpoint in *F: ~~~~~~~370 / >365
Fuel %:~~~~~~~~~~~~~~~~ 0.8 / <2.0
Antifreeze: ~~~~~~~~~~~~~0 / 0
Water %: ~~~~~~~~~~~~~~~0 / <0.1
Insolubles %:~~~~~~~~~~ 0.3 / <0.6
Overall, VERY happy with the performance of this oil. Wear numbers are lower then normal averages for this engine. Engine was ran quite hard during this period as well, redlining it quite a few times and battling extensive up-hill's in 2 and 3rd gear for minutes at a time on the trip I took prior to the drain. Engine was definitely put to the test! I'm not that easy on it!
Comments:
CHROMIUM: ~~~ 0 / 0
COPPER: ~~~~~ 1 / 2
LEAD: ~~~~~~~ 1 / 2
TIN: ~~~~~~~~~0 / 1
NICKEL:~~~~~~ 0 / 0
MANGANESE:~~~ 0 / 0
SILVER: ~~~~~ 0 / 0
TITANIUM:~~~~ 0 / 0
POTASSIUM:~~ 0 / 1
SODIUM: ~~~~~4 / 14
Properties:
