1 - 20 of 20 Posts
I thought the engine bay was looking a little dull so I thought I'd remove the cover to expose the headers. However, the stock headers aren't exactly pretty. I'm not interested in installing aftermarket headers so I thought I would throw some high temp paint on the header cover. I went with black to keep it simple, red might look a little cheese-ball.
On mine, yes it is.
Doesn't it look a bit like a heart when in red?
thats really cool. how much was the paint?
Engine paint, whichever is at the local parts store.
Ok thanks
Here's a thought- has anyone tried painting the header with that high temperature paint? That "clamshell" cover is just plain ugly compared to a header no matter what color it is. I anticipated the factory header to look a lot worse than it does. I guess there's not much to lose in trying it as worse case, you just end up putting the cover back on.
That is what I was planning to paint, but mine is VERY rusty, already.
Edit: I've been thinking of painting them flat black or charcoal/graphite, anyways,
For the header cover (technically a heat shield), just make sure that the engine has been OFF for a while.  Otherwise it will be very, very hot (and could cause a nice burn).
just to ask has anyone looked at there cover after driving for awile? it the hightemp paint fading at all? fyi even if u paint the header with hitemp paint it will burn off. and even if you use the really high temp paint. tried this on my honda crx once.
If you only put one coat on it burns off. I painted mine white and it's starting to look dull and brownish
1 - 20 of 20 Posts
