.....is crucial to proper operation of your rear brakes!
Who knew that?
I just had my 05' Honda in for a brake job and the owner of the shop shared a little known 'tip'.
'Be sure to use your parking brake several time a week when you park the vehicle. This keeps the rear brake calipers adjusted mechanically so they work to help the front brakes like they are designed to'.
Otherwise, the rear brakes will NOT support the front brakes, and the front brakes will wear out sooner than they are supposed to.
Works that way on all models, drum or disc style.
I never used my park break in the past, and the rear adjuster had 'frozen' in place.
It required solvent, cleaning and adjustment to free it up again to it will work properly.
Sooooo......use that parking brake frequently to prevent future problems.
Who knew that?
