piller creek noise
2782 Views 6 Replies 5 Participants Last post by  yanges
anyone having ratteling noise should have thier xb checked out its a huge problem go on scion life and check it out its fixed under your warrenty though befor 36,000 check this tsb out
. my windshield cracked because of it and no its not a rock its called a stress crack if you get one its basically starts as a straight line directly from your piller. im getting mine fixed tuesday.
http://www.mediafire.com/?aazv9dmh2tg
Thanks... I was going to post about this the other day, but forgot...
Here's the juicy info ;)
TSB # NV001-08 only applies to vehicles w/ VIN numbers before VIN_ JTLKE50E#81030544
Approximately 10 – 15 mm (0.39 – 0.59 in.) forward of the 2 indicated spot welds, use
a punch to dimple the sheet metal inward 0.5 mm (0.20 in.)
yeah i know i did all my research and im really hesitant to let them take my car apart liek they would ahve to , but my windshield cracked becasue of it anf if i replace my windshield and it happens again ill be pissed so why not fix it im pretty nervouse about it but well see ill keep you posted
and i know my vin is after that production change but thier stil fixing it.
So dimple the metal and this will fix the body flex? Thanks for the information, but I find it hard to believe a hammer and punch will stop the body from flexing enough to save the windshield from cracking.
I have the "A" pillar creaking and now when I take off from a stop I hear a noise from the dash, but I believe the noise is just the plastic parts flexing with the body.
Hope this fix works for you, let us know if the dealer creates more problems when taking the dash out.
I have just started to hear a popping noise from the passenger front side I thought that it was something in my glove box or in the door cup holder but I took everything out and its still there. I have been passing it off since it has been below 0 the last few weeks. Hope that is all that it is but I'm going to have to have it checked out at the dealership.
hey Eric
so where do you find TSB info? is it listed somewhere?
